I am looking for advise on replacing my water heater. I have a 2001 3788 with the original water heater. I noticed today when looking in the hole, that there was some moisture on the mounting bracket with a slippery feel and some crystals in it that must be coolant. It doesn't appear to have come from either of the hoses, but up from under the case of the heater. I am assuming that I need to replace the water heater, so some questions came to mind while imagining how to do the project.
The water heater is screwed into place using the front bracket, so I assume there must be a similar rear bracket. If so, did Bayliner typically screw this one down too. You would either have too remove the vacuum generator to come in from the front side, or somehow reach over the top. When you remove the coolant hoses should you somehow clamp them off or use a wood plug to keep coolant from flowing out or will the lack of a vent in the system keep most of it contained. The coolant hoses off the SB engine going to the heatercraft unit have a valve on the incoming hose to shut it off for servicing. The potable water and electrical connections seem straight forward. I drained the heater previously when I removed a faulty backflow valve and that was fairly simple. I am probably going to replace it with the same unit and it appears that the opening is adequate, but I may have to move the central vac unit out of the way.
Thanks - Open Wide
Thanks - Open Wide
