Not being a carpenter, can someone share where we may be able to find replacement hinges used on the cabinet doors throughout the late '80s motoryachts. We need a couple of the right angle jamb edge type. Your assistance is appreciated.
Replacement cabinet door hinges-gctid342425
Ken, I suspect it will be easy to replace once identified. there were a number of suppliers used on the boats, depending in part on which specific factory the boat came out of, and on what date. Can you post a pic?
Here is the picture (if it transfers).
That looks like a standard "Euro Style" hinge used commonly on frameless cabinets. You should be able to get new ones at the local Lowes or Home Depot.
Thanks for the suggestions of Lowes & HD. Sometimes I just give up on "local supply" since we have a lack of it in the NYC area. I miss Ft Lauderdale and Annapolis for keeping the boat up.
Will take one off and bring it up for reference.
Thanks again!
