3270 - Sunrise checklist-gctid361746
  • iceclimber
    Remember it's a gas engine. I found a lot of 20 on Ebay and bought them all.
  • mmichellich
    What frel filters cost $3 each? I need to find your source.
  • iceclimber
    mmichellich wrote:
    Wow on our 47 that sits 7 months untouched, in the spring, I unlock the salon door, find keys and insert them, preheat both engines for a few seconds and fire them up. Quickly get on dock and check out amount of water flowing in exhausts. While those two big boys are running I check their gauges and do the same thing with the gen set. All the spring engine work is done in the fall. That is all an old fart can remember year after year.
    The first thing on my NEW checklist is to trade boats with you.
    On the oil question....hmmm good question. I actually sort of thought to go without the oil change since it literally had 20 minutes of run time on it. This boat had a history of marginal care (that is why I could afford it) and we did had some oil sludge issues. Last season I pumped a couple low hour changes through, and I guess I am just over cautious? Plus I am running the boat 5 hours north to it's new home port. I'll fire it up and see how the oil looks on the stick; if I don't see any moisture I can let it go.
    On the fuel filters? Because they cost $3.00 and it makes me feel good.
  • JimMc
    There is no reason to change the oil if it was changed in the fall as you should.
    • Verify Hoses and clamps.
    • Inspect all thru hull fittings and seacocks
    • Impellers in place
    • Check all engine fluid levels
    • DRAIN PLUG IN HULL if you have one.
    • Reconnect batteries.
    • Verify water in batteries
    • Bottom paint if needed
    • Verify engines reach proper temperature and pressures
    • Verify proper Wide Open Throttle engine RPMs once on the water
    • Inspect all underwater gear before launch
    • Sanitize fresh water system
  • mmichellich
    iceclimber wrote:
    305 fresh water cooled gas engines, Westerbeke Generator, and reverse cycle heat.
    Still cold here, but planning to sunrise the boat myself this year to save a few bucks - and I've never done it before. The engines and genny got oil changes before getting winterized by the marina. I don't
    know if anyone has a decent checklist they could share? This is what I am guessing at...and did I mention I've never done it before.
    Motors:
    New fuel filters
    Attach the impeller hoses
    Close the drains on the water jackets
    Assemble and close the strainers
    Open the thru hulls
    Start the engines
    Warm 'em up, change the oil and filters
    Generator
    Open the thru hull and start ? Was going to consider skipping the oil change as it had literally no time on the new oil.
    Flush and fill the water tank, check the pump and hot water, open the thru hulls for the reverse cycle and head.
    What am I missing? Probably a ton of stuff. Thanks in advance for your help.
    Why do you plan to change oil and filters sine engines have no hours on them since last changed?
    Why are you changing the fuel filters?
  • mmichellich
    Still cold here, but planning to sunrise the boat myself this year to save a few bucks - and I've never done it before. The engines and genny got oil changes before getting winterized by the marina. I don't know if anyone has a decent checklist they could share? This is what I am guessing at...and did I mention I've never done it before.
    Motors:
    New fuel filters
    Open the thru hulls
    Start the engines
    Generator
  • iceclimber
    started a topic 3270 - Sunrise checklist-gctid361746
    Motors:
    New fuel filters
    Open the thru hulls
    Start the engines
    Generator
