Watermaker in a 32-gctid361580
    I finished installing a watermaker in my 32XX. The parts of my body that isn't covered with scabs is bruised. The first Photo is a panel, that I fabricate from Starboard, to fit in the available space that I mounted all of the components to. The second is the panel in place. The third ts the pump and membrane mounted. The fourth is rhe control panel
    [img]/media/kunena/attachments/vb/664560=25504-Watermaker 1.jpg[/img]
    [img]/media/kunena/attachments/vb/664560=25505-Watermaker 2.jpg[/img]
    [img]/media/kunena/attachments/vb/664560=25506-Watermaker 3.jpg[/img]
    [img]/media/kunena/attachments/vb/664560=25507-Watermaker 4.jpg[/img]
    Very nice Bill!
    Is your boat in the water? How does it work!
    We're trying out ours in a week or so, Cant wait!
    I'm pretty sure that the watermaker will put a whole new dynamic on your boating pleasure!
    Unlimited showers.
    If someone accidentially leaves a sink on you're not out of water.
    Stay on the hook forever!
    The list of benefits goes on and on!
      ksanders wrote:
      Very nice Bill!
      Our boat is on the hard. The company I bought the watermaker from wants to be there when I turn it on for the first time and go over my instalation. We will will do that in May and yes on the hook till we run out of diesel
        What is the GPH rating and the approximate cost for parts?
        Thanks,
        Steve
          Wish I could see a bit more in the picture. Could you post what location you chose to dump the water back into your fresh water tank or did you do that at all?
          How does the system know when to quit - does it have a sensor or manual?
            The unit is rated for 150 GPD (6.25 GPH) The Water goes into the tank through a Tee that I put in the fill line. Very similar to the photos that Ken Sanders posted of his watermaker. The unit is manual for the shutoff. Photos are almost imposible because of the lack of room in the area where it is located. Total cost was under 5 1/4 boat bucks.
              Thanks Bill
              I was planning the same manual approach with no sensor and dump into the unpressurized portion (but not the big fill line) with the maker well above the height of the top of the holding tank. I should be under 2 boat bucks from what I saw at the big box home store but I do not have to contend with salt water.
              There is penny wise and pound foolish and then there is me - just inordinately cheap.
                bobsyiruncle wrote:
                Thanks Bill
                The Manufacture of my unit specified non-pressurized line and not a vent so that left the fill line. It was simple once I saw how Ken's was done. Just cut the line and install a Tee fitting
                  Nice install.
                  Just curious why there was no level sensor added to the system to indicate a full tank?
                  ________________
                  1998 Bayliner 4788
                  1989 Bayliner 3270 - SOLD-
                    There is a tank level but it is not part of the watermaker
                      Luv ya Bill - I am not ready for even more complex and fancy high technology to rule just yet
