Hino 175 Manifold heat exchanger Cores-gctid342176
  • Hino 175 Manifold heat exchanger Cores-gctid342176
    Hi,
    Can anyone tell me if these some secret to getting the heat exchanger core out of the Hino 175hp manifold or is it a matter of flogging it with a rubber mallet and hope you don't wreck it????
    Need some help on this, getting frustrated with it?
    Regards,
    Allen
    Hi Allen
    If they are the same as my 310 hinos, I just pull of the end caps, remove the two orings and push them out. From memory the first time I did them I think one was tight and I used a hammer and a block of wood to get it moving.
    Cheers.Jim
    Gold coast.
      Hi Jim, Gold Coast Qld???? If so I recon I've seen your boat down Tipplers way. Anyway, probably the same, I've removed the ends and O rings and given it a hit with a rubber mallett and it won't move and I don't want to wreck it as another is looking like a grand to buy. Guess I was just trying to make sure there's no hidden bolts or pins somewhere to stop it moving, I guess it's belt it and see.
      Regards,
      Allen
        Hammer and block of wood worked better than rubber mallet for me.
        MMSI: 338030604
          With ends knocked loose and o-rings removed mine slid right out.
          Nobody gets out alive.
            If you do ruin it getting it out, I have a spare I would like to sell. I took
            it on a Looper trip and never needed it.
