3460 gas leak-gctid359256
  • boatworkfl
    Check all the conections first, then come back to us.
    Guest started a topic 3460 gas leak-gctid359256
    Hi There,
    My 3460 has arrived in the Philippines so I hope to see it today for the first time today. I have most repair issues covered but have a Diesel leak from the forward tank. Is there an easy way to repair while the tank remains in the boat or must I remove for repair. If it must be removed which I suspect is the case how do I go about doing so.
    Thanks in advance for any tips you can pass on.
