Hi There,
My 3460 has arrived in the Philippines so I hope to see it today for the first time today. I have most repair issues covered but have a Diesel leak from the forward tank. Is there an easy way to repair while the tank remains in the boat or must I remove for repair. If it must be removed which I suspect is the case how do I go about doing so.
Thanks in advance for any tips you can pass on.
