8kw Westerbeke problems
    Bought this '97 4788 knowing the raw water pump was removed from the 8KW Westerbeke genset, replaced the pump last week. It hasn't been started in probably 10-12 weeks while pump was out. Had to replace battery, but got it all hooked up and now it won't start. Turns over just fine, but refuses to start. Checked movement of the fuel solenoid, works fine. Checked fuel filter, plenty of diesel in it. Any ideas? I'm thinking it probably needs priming due to sitting for that long, but I've no idea how or where to perform this procedure.
    1997 Bayliner 4788
    'Southern Charm'
    Vancouver WA
    How long are you holding the preheat down? Mine won't start unless I hold it down for about 20 seconds even in the middle of the summer.
    Also, the solenoid might move just fine but it won't engage. Mine gave me trouble for a while until I replaced it, quick 15 minute job but works like a charm now.
    Have someone try to start it while you look down at the solenoid.
    Finally, check the manual shutoff for fuel and such. Many times I will turn off the power and fuel to things that I am working on and then I will wonder why they won't start.
    Ships n Giggles
    1993 Bayliner 4388
    MMSI# 367412710
    Day Island Yacht Club
    Commodore
      When the Preheat switch is held down three things happen 1. The glow plugs will energize 2 the fuel solenoid will pull down to open the fuel supply 3. the fuel pump will start clicking.
      Absent any one of the three it will not start. Have a friend hold down the preheat when you have your face right at the genny to watch and listen for 2 & 3. Westerbekes are self priming due to the electric fuel pump
      so bleeding lines is not necessary if the fuel pump is working.
      "Adios Dinero"
      Photo Credit: Whiskywizard
        All great advice, thanks! Didn't realize it had an electric fuel pump. I was holding the preheat down for 10-15 seconds, will try a longer session next time I'm there and have some help for listening for both 2 and 3. Pulled both turbos for rebuilds, PITA. (Pain In The A_ _!) Got a few projects going on. (Sigh...)
        1997 Bayliner 4788
        'Southern Charm'
        Vancouver WA
          With the fuel pump it could be as simple as the grounding wire becoming loose ( mine did ) there are two types based on the year, cylindrical and Square, The fuel solenoid has two amperages to Pull on and Hold. In a pinch you can pull it on manually and tie it off to stay on as the linkage sometimes gets corroded and sticks. Hope this helps.
          "Adios Dinero"
