prop size-gctid684846
    I just purchased a 1989 Arriva 2350(?) without a prop. Boat has 7.4L bravo one set-up. Will be used for crusing and little speed. What is the best size and pitch for me?
    Welcome to BOC,
    if you have a friendly Mercruiser dealer or prop shop, locally I suggest going there and seeking their advice. There will be a range of suitable props that will fit but if you find an agreeable shop they will usually let you trial them.
    You might need to change out a few to suit how you are personally going to use your boat.
    Hope it all goes well.
    Ian B)
    Ian & Emma
    MV "LaPaloma"
    1990 4588
    Bay of Islands
    New Zealand
