Water Circulator Replacement-gctid356521
    Looks good to me!
    Hey Rick!
    It's open cooling system... I ended up with this pump...
    http://www.summitracing.com/parts/MAA-9-42606/?rtype=10
    And... They matched the price for the one I found on Amazon!
    I also got this - YLM624AV - I hope this is the one you suggested - I went back on a few old posts where you and I discussed the distributor and I HOPE this is the one you suggested...
    http://www.summitracing.com/parts/MAA-YLM624AV/
    Let me know if there is something you would suggest other than what I have here.
    Thanks!
    PS - WHAT ABOUT UPLOADING PIX?
    Craig, this would be your engine coolant circulating pump.
    I don't recall whether your engine is close system cooled or open.
    If open, you'll want the Marine Circ pump.
    The impeller will be SS or Bronze, rear cover will be SS and the ceramic seal will be slightly different for raw water use.
    If Closed Cooling, you can use the automotive version Circ Pump of which is the early Chevrolet short body.
    These are less expensive and they won't know that they've been installed on a Marine SBC.
    Guest started a topic Water Circulator Replacement-gctid356521
    Hello Gentlemen! and ladies...
    I am replacing the circulator on my V/P. It's a 1983 Bayliner 2150 Sunbridge Ciera with the 225D motor (Chevy 305) which has been upgraded to a 350 (same circulator).
    The current circulator part number is marked 10108455 but I can't seem to find a replacement with these numbers as a cross-reference. This is the circulator that I THINK it should be but could someone help me out here? (see link)
    http://www.iboats.com/Circulating-Wa...view_id.171891
    I have, as usual, posted some pix for you to take a look at... ((Well I tried to but can't seem to upload photos now... Can someone help me on this issue also? Geez!!! I used to be able to post pix but now the site has changed since I was here))
    Thanks!
