Never mind sorry I asked
Bennett trim tab indicators-gctid353825
I have the bennett automatic system an never use it. The only time I look at the indicators is after leveling out the ride to see what angles they are running at. I may glance at them while docking just to make sure I have raised them all the way up.
1998 3055 Ciera
(yes, a 1998)
Previous boat: 1993 3055
Sea Doo XP
Sea Doo GTI SE
I never understood why you would need indicators..... you should be able to tell where they are at by the attitude of your boat , No?
I have the NMEA Lowrance setup and can display the tabs on the LMF 400 guage, Globalmap 6600c Chartplotter, and even on the Sonar.
dwoodford wrote:
Just because I like the bling
Hi Jim,Was it a true replacement from the factory ones that cam
[img]/media/kunena/attachments/vb/656934=24910-717_rev.jpg[/img] e on the boat or did you need to run extra wires to power the indictor, etc.?See my picture it would be interesting to get if it's a quick retro-fit.Thanks,Steve
:thumb still confused?? cant you tell by your boats attitude where your tabs are ? I can ....... as I am sure most here can? Not trying to be an a$$ but really wouldn't the money be spent better somewhere else..... JMO
For example if you come off of plane and get into a following sea with your tabs down it can be very danderous.
If you're up on plane and one tab is having to be deployed allot more than the other its a good indication that you need to re-arrange your load.
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
http://baylinerownersclub.org/media/..._rev.jpg[/img] e on the boat or did you need to run extra wires to power the indictor, etc.?See my picture it would be interesting to get if it's a quick retro-fit.Thanks,Steve
Jim McNeely
Twin 5.7s with Bravo2 drives
Brighton, Michigan USA
MMSI # 367393410
http://baylinerownersclub.org/media/..._rev.jpg[/img] e on the boat or did you need to run extra wires to power the indictor, etc.?See my picture it would be interesting to get if it's a quick retro-fit.Thanks,SteveHere is a link to the installation instructions https://"http://www.bennetttrimtabs....structions.pdfTomBennett Marine Attached files http://baylinerownersclub.org/media/...5000.jpg[/img]
Tabman wrote:
Steve,
The EIC electronic indicator control fits in the same "footprint" as the rocker switch, so it can replace it.
Here is a link to the installation instructions https://"http://www.bennetttrimtabs....f<br /> <br />
Tom
Bennett Marine
1998 3055 Ciera
(yes, a 1998)
Sea Doo XP
Sea Doo GTI SE
Tabman wrote:
Yes, the EIC has a relay module that will replace the one for the Auto Tab Control. There is a plug for the ATC to connect into it.
Tom
Bennett Marine
1998 3055 Ciera
(yes, a 1998)
Sea Doo XP
Sea Doo GTI SE
