Side window leakage on my 1998Cierra 2452-gctid352961
    I recently purchased the above boat.
    It seems to be missing either a sealing gasket or piece of window frame where the sliding windows come together in the middle.
    This space allows water to enter during washing or rain.
    Can anyone help?
    In the newer models the windows are in an aluminum tract that is lined with felt . if you could include a picture it would be helpful
      these windows should be roughly the same only newer the tracks can get plugged the felt moves and covers your drains or aluminium weld can break easy.once we see pics of yours we can help you better
        Right now the boat is under shrink wrap, but the drains are clear.
        The side windows slide shut, in the middle there is no form of seal.
        Do they come from the factory with anything in the middle to make them water tight?
