Hi guys,
It's been a while since I've posted. I've been so busy with work and any free time I had was being spent on the water! I was having no problems with the boat for the first time during my ownership and it was sheer bliss to be able to just walk on to her and start the engine and go! Until recently!:livid:
I had previously mentioned in one of my posts that the bilge was taking in a bit of water but nothing the pumps couldnt handle. The response from some of you guys was to keep it in the water till it got out of hand and also to try and identify where the water was coming in from.I had a mechanic check it out and left him to come back with the reason and solution for the leak.BAD IDEA!!
I kept an eye on the water level and for the time being, it was all good...till last week.
I got a txt from the marina saying ' water in bilge,please come quick'. Got to the marina in 15 minutes to find out that the pump had stopped working and in a space of 4 hours the water was up to the lower edges of thE pulleys/belts so the oil pan at this point was completely submerged.
The mechanic who was asked to find the leak had let me down severly.No one to blame but myself for being such a fool!! I had no choice but to pull her out of as the sight of all that water in the bilge was unbearable.
Now the real issue. How do I know where the leak was from? Who are the usual suspects? Exhaust bellows? Transom Seal kit etc? If anyone could give me a list I could simply replace the lot to eliminate any chances of this happening again. Engine is 5.7 Merc with Bravo III drive. Any ideas/tips on this? Much appreciated guys,what would I do with out The Boc
