Damp inverter= ruined-gctid351699
    My inverter got ruined last season by dampness? in the engine compartment. They are supposed to be mounted close to the battery which it is and of course the batteries are in the engine compartment. so how do you prevent yours from ever seeing dampness and getting ruined? I'm looking for tricks of the trade, are there any?
    Inverter is not supposed to be in engine room of gas powered boat - it is not spark protected. That part out of the way for those that have mounted in a bilge (diesel boats) and not had problems with water is because they located somewhere that stays dry - look for a place that has dust and you are on the right path for the type of place to put it.
    Generally - higher up and further forward are good directions to go.
    It takes big cables and passing through a bulkhead to install properly in a gasoline powered boat, sometimes you need to move the batteries as well.
    Nobody gets out alive.
      +1 I was going to say the same thing.
        Xantrex does/did make an inverter that can be mounted in the engine compartment of a boat, Carlos has one.
        Ken
        300SD all options sold.
          Thanks for the info, my bad! In reading threads posted a couple of years ago I understood that was the place to mount them. I guess the question should have been where should I mount my new inverter but I see theres a tread all ready started on that one.
            You need to do one of two things. First off the inverter needs to be inside the cabin away from the engine compartment.
            So you either need to have big mother cables from the batteries to the inverter capable of the distance or move your batteries we closer to the inverter which is inside. You should not how ever put batteries inside the cabin.
            1989 Avanti 3450 Sunbridge
            twin 454's
            MV Mar-Y-Sol
            Twin chevy 350's inboard
            Ben- Jamin
            spokane Washington
              Yes, but there's only one model, is extremely expensive and rare, and discontinued. So usually it's safe to assume it's nto that one. And that one is also waterproof, so it wouldn't be ruined.
              If you have anything other than a Xantrex IP1012, get it OUT of the engine room now.
