PLEASE HELP SUPPORT OUR SITE
My boat is out of the water and the outbords have been power washed. I would like to paint them and want to know what type of antifouling paint should I use. The boat will be in fresh water in Lake Ontario
wrong there ricko....sand the whole drive down....get some chromate primer and spray that on after you fill in any large pits....sanding smooth after the application....
Recently posted before and after pix of my outdrive which I had cleaned up, primed and painted with 2 coats of Interlux TriLux33 to prohibit growth while in the slip for the season. Obviously don't know how well it will work yet but I'm sure it will be better than regular paint and recoats will be a simple process as needed. By the way I'm on Lake Michigan so pretty much the same watwer temps.
The media blasting makes quick work out of removing the old loose paint and cleaning up any hard-to-reach corroded areas. You can sand additionally after blasting.
It was just a suggestion......, if you don't mind sanding, then there ya go.
Your finish job will be only as good as your prep work will be.
Note that the Zinc Chromate is to be a thin coating, not an excessive coating.
Rick E. Gresham, Oregon
