Coval Molecular Coatings
    Anyone ever heard of, or used, Coval Molecular Coatings, as a bottom coat?
    I normally look at all the "amazing" products as a bit of snake oil. But, I'm negotiating on the purchase of a 4788 and the fellow that owns it currently went on and on about how special it is. (I got this third hand from the broker.)
    I guess if I buy the boat, i'll be a fan, but I figured it was worth asking the conventional wisdom.
    file:///C:/Users/tonif/OneDrive/Docu...ta%20Sheet.pdf
    Toni
    Yelm, Washington
    1997 Camano Troll (for now)
    Link doesn't work
    Irony
    1989 Bayliner 4588 - EH700TI
    Portsmouth, NH
      is that a ceramic coating? you linked to a local file on your hard drive. It would have to have some bio-cide on it I would imagine for it to work. Otherwise its just a slick surface, if that were true if you put a teflon coated pan into the water it shouldn't grow barnacles and algae... curious if that is enough.
        Link to the manufacturers page: https://covalmolecular.com/products/coval-marine/
        Sounds interesting but I'm trying to go to no bottom coat since I don't really need it.
        1984 2150 Ciera
        Southwest Michigan
          thanks for fixing the link. I have trouble turning the computer on, so me having the wrong link is to be expected. Appreciate the help.
          Toni
          Yelm, Washington
            After reading the Mfgs pitch on the link above, I'd say that if it is truly being used in industry (large ships, oil rigs etc.) then it may be a viable product that works. It may also be very expensive and/or require special application which is why it may not be a "common" solution. With all that said, if the boat is in good/great shape otherwise, is what you are looking for and passes all your inspections, surveys (If performed) and the price is right, go for it. Worse case scenario is that it doesn't hold up as expected and you have to revert to having the bottom coated with a more conventional covering.
            I'll be reading more about it as time permits as it does sound interesting. Might steal one of the admirals Teflon pans and hang it in the water to see if T4T's idea "pans" out.
            1998 BL Ciera 2655 Sunbridge LX (Special Edition)
            "Sea Flights"
            5.7L 2bbl w/Thunderbolt Ignition and raw water cooling
            A​​​​​​lpha I Gen II Sterndrive/1.45:1 gears
            M15.25 X 15P Black Max prop
            MFG Extra's - A/C, Fresh Water Engine Flush port, HWH and Windlass
            Docks @ Punta Gorda, Florida
