Rebuild trailer or get a new one?
    I have a 2003 1952 Bayliner with the appropriate trailer, which is in need of a rebuild. I mean everything from except the wheels, tires and the jack. Its a bunk trailer. What do you guys think is the best thing to do?
    2003 Bayliner 1952 cuddy
    You are going through what my brother in law just did. Save thee wheels, tires and jack and do what he did. Buy a new one. That’s the end of the story, but along the way there was a lot of drama. He returned from a better than usual season of gill netting salmon in Alaska and spend a week getting their camper and boat ready for a vacation that included some crabbing. He took the boat trailer to a shop for some repairs and was told the trailer was done. My sister in law has always been tight with a dollar, as the saying goes “squeezes a nickel so tight the Indian is riding the buffalo”. After a week of shopping, her auditing the shopping, him explaining why that trailer from Harbor Freight won’t work, complaints about the boat not being ready, you can guess the whole scene, they ordered a new trailer.
    Good luck.
      Does it have brakes? How are they actuated?
      Painted or galvanized?
      Salt water use or fresh?
      Is there a place where you can drop the boat in the water and work on the trailer for 1-3 hours? (for one or two installments depending on condition of the hardware)
      Post a picture and your specific concerns.
        Get a new one. After 17 years of mostly salt water use, my galvanized Escort trailer was so rusted that the junk yard accepted it but wouldn't pay anything.
        A new one was less than $3000. The place I bought it measured the original before I scrapped it for the placement of the bunks.
        1998 Capri 1950CL
        3 Liter MerCruiser
          It is used to tow about 8 miles to a saltwater ramp in Plymouth Ma. Its galvanized and the brakes where cannibalized by the previous owner so there are NO brakes on it now. Springs are shot, all hangers for the fenders are literally hanging, bunks need full replacement, meaning hardware is trash. Have looked up almost all parts to rebuild, minus the brakes and I am at $1,253.00. So it look like a new trailer is going to be the most economical route. Wgander, what trailer did you get? And you Pcpete?
            I’ll ask the brother in law what he got.
              I had mine built locally (Lakeside, near San Diego) by FE trailers. I got LED lights, no brakes, torsion suspension instead of springs and the Vault system for wheel bearings (fully enclosed, no servicing.
              1998 Capri 1950CL
              3 Liter MerCruiser
                If you want to work, rebuild the one you have. If you don't want to work buy a new one. Simple as that.
                  A friendly FYI..... it would appear that the Vault system is very similar to that of a Bearing Buddy.
                  A Bearing Buddy's function is often misunderstood. They apply pressure to the hub, but do not add any grease to the wheel bearings.
                  Point being.... do not think that by pumping grease into these, that you are actually adding or exchanging grease within the wheel bearings!
                  In order to actually exchange-old-for-new grease within wheel bearings (without disassembly), we need one of the EZ-Lube, Sure-Lube or Super-Lube style spindles/hubs.
                  Here are the differences between the two:
                  Click image for larger version  Name:	bearing buddy vs EZ Lube style.jpg Views:	0 Size:	321.4 KB ID:	534582
                  Here is another example:
                  Be sure to spin the wheel as the new grease is being pumped in. Dynamic -vs- Static!!!!!
                  Rick E. Gresham, Oregon
                    Get an aluminum one!
                    https://southcoast.craigslist.org/bo...967297818.html
                    Esteban
                    Huntington Beach, California
                      Think I'll give them a call, thanks Guru!
                        They have Loadrite galvanized bunks for $2,300, minus whatever I get in a trade. Think I got a new trailer coming.
                          2016 Bayliner 215 Deck Boat
                          Mercruiser 4.3 220 HP Alpha 1 Gen II
                          2003 SeaRay 176 SRX Bowrider
                          1988 Sunbird 170 Bowrider
                          Evinrude 88 Special
                          1970 Salem Skiff 13.5 foot
                          1992 Johnson 40HP.
                            Got two different quotes both came out to the same numbers, $2,300, with no brakes. $2,900 with brakes. Do I need brakes for a 2,200 lb boat?
                              No one has ever complained about having trailer brakes..... but they may complain about NOT having them if the tow vehicle is on the lite duty side!
                              I would also make sure that this trailer is equipped with EZ Lube, Sure Lube or Super-Lube style hubs/spindles...... NO Bearing Buddies!
                              Good luck!
