Music while on hook
    Music while on hook
    Been putting off adding 2 more speakers so we can hear music while on hook...usually spend a lot of time in the water. Always feared a dead battery so was climbing in and starting boatI all the time.
    Was at academy and had revalation....I picked up a bluetooth speaker pair that is waterproof and even floats. It supposedly has ten hour pay time before recharge.
    will throw it on swim platform next time and see how it does.... sounds great at house.
    2008 H210SS Four Winns
    Volvo Penta 5.7 GISX
    Prior: 1997 2050SS Bayliner
    Brad / Texas Gulf Coast
    Ive been using a Bose mini link exclusively for my tunes, surprisingly the battery will last longer than I can. I recharge it via the usb cord while cruising to and from, same with the iPad and phones.
    "THE FIX"
    Misc. projects thread
      Originally posted by TX H210 SS View Post
      ................... Always feared a dead battery so was climbing in and starting boatI all the time.
      Hopefully this boat has two individual battery banks....... one bank that is dedicated for engine cranking (this bank would be held in "reserve" when on the hook), and one large bank of Deep Cycle batteries for all else. And of course, you would need a means of selecting one or the other.
      Rick E. Gresham, Oregon
      • TX H210 SS
        TX H210 SS commented
        Only one crank battery...I installed a pergo dual switch and charger....been stalling but need to get 2nd bttry and cables. Will need to install on port, but main and switch are on starboard.
      I use a EU Boom. Waterproof and it floats. I also use it for sound for the TV when we watch movies. Versatile and sounds great.
      Ted G
      The Great PNW
      86 2850 Contessa SB
      Designers Edition
      Mercury 350 Mag
      290 Volvo DP
        I have a TDK A33 with blue tooth and rechargeable battery. Great sound, waterproof and long battery life. I also use my installed Kenwood stereo while on the hook. To the OP, quick, get two hefty golf cart batteries for your house bank so you can rest easier
        Johnson Point, Olympia, WA
        1989 2855
        Horizon 6.2 and Bravo II
          TX, me thinks for your sport boat, just go with one 12 volt combination deep cycle for your second battery “bank” the bigger the better IMO
          "THE FIX"
          • TX H210 SS
            Sounds like a plan....I know I need heavy cables to make the run from ports to starboard....I know the pos will hook to bttry switch, but pondering where to hook the negative.
            I have plenty vacant area for bttry 2 but the access to that area isnt too friendly.
          As my kids say "you old man," bt perfect level for background music (speakers on my boat are right in your ear difficult to hear conversations) plus advantages stated above, no battery drain, aux for tv, sounds better than marine speakers (at least mine). Kids like the amp boat speakers.
            I'm sold on the bluetooth wireless speaker for sure....I was going to get an amp as wires are already run for it and add speakers 5 and 6, but now I will just get 4 replacements for the blown ones I have.
            hard to tell in pics I have but main bttry is on starboard side behind a molded wall with just enough of a cutout for the bttry. It sits pretty much under the thru side hull exhaust tube, which is same location and access I have for bttry 2 on port side.
            I will measure but boat had 8.5' beam so that's about the length cable I need with the routing...not sure gage i need to account for drop.
                The negative cable for your second battery “bank” will connect to the same lug as the current battery’s negative cable connects to. Most likely a stud located at the rear of the engine block. The battery cable size will likely be the same as the current cable size, your cable runs would be fairly short IMO.
                "THE FIX"
                  Only one crank battery...I installed a perko dual switch and charger....
                  Toss that Perko battery switch in the recycle bin, and get yourself a decent MBSS.
                  Two 6 volt golf cart batteries, in series, works very well for a House Load Battery Bank, and will give you the Amp Hours needed.
                  We want Amp Hours.... not necessarily voltage alone.
                  The MBSS (main battery selector switch) should be accessible from outside of the engine bay, where you will have quick access to it in the event of an emergency.
                  Your engine will serve as the "system negative common", and will be where you will want to take the Negative cables.
