US Marine plastic swim/boarding platform replacement
    Hi, I am the original owner of a US Marine built 1989 Maxum 2000 SR, Bayliner's sister boat. I need to replace a cracked swim/boarding platform. This is a single person, starboard side, with two hand rails and through transom bolt holes 15" wide.
    Can anyone tell me this part number so I can do a search OR suggest an aftermarket platform that will fit my bolt hole pattern OR can I reinforce this cracked one for future use
    Some pictures may help.
    1998 BL Ciera 2655 Sunbridge LX (Special Edition)
    "Sea Flights"
    5.7L 2bbl w/Thunderbolt Ignition and raw water cooling
    A​​​​​​lpha I Gen II Sterndrive/1.45:1 gears
    M15.25 X 15P Black Max prop
    MFG Extra's - A/C, Fresh Water Engine Flush port, HWH and Windlass
    Docks @ Punta Gorda, Florida
      Sounds like a good candidate for scrapyard swapout. Those things just never seem to wear or break ..........unless you back them into something
        Is yours similar to this? Width 27 1/2", Span 20 1/4", mount holes 15" OC x 4 1/2" OC, Apx. 13 degree tansom angle. Handrail holes 17 1/4" OC x 3/4" dia. This is off a 2000 2452. If it will fit, $20 plus shipping and it is yours.
          I've got the original that was on my 1987 bayliner, should be the same or similar to the one above.
