1994 Bayliner - 2855 Ciera Sunbridge - Prop Size needed
    New to the boating world, trying to sort out a new prop but no markings on current one! Lots of digging and a confused..
    Engine is Gas V8 Stern Drive
    7.4L Mercruiser Brovo II
    Thanks for the help!
    John
    Try looking it up on the Bayliner Customer Care website:
    http://www.baylinercustomercare.com/catalogs_index.html
    2004 Monterey 282 Cruiser
    Twin Volvo Penta 5.0GXi-E
    SX-M 1.6gr Outdrives
    Docks @ Punta Gorda, Florida
      I went to the link above, and according to the US MARINE/Bayliner parts catalog the original prop was a 16 X 14. OEM part number was 34196.
        The 16 x 14 seems incorrect for a boat that size with a Bravo drive. It’s more likely a 17 1/4 x 21 or 18 1/4 x 19 or similar.
        This all is dependent on the ratio of the drive as well.
        I’d suggest looking closely at the exterior portion of the prop hub between the blades to find the part number or or the size stamped into the aluminum. Sometimes it’s hard to see. If all els fails you can take the prop to a reputable prop shop for identification.
        BTW: Mercury prop calculator has it a 17 1/4 x 21 IF it’s running a 2.0:1 final drive ratio.
        "THE FIX"
        '93 2556
        Misc. projects thread
          No markings anywhere, brought to repair shop and they didn't help either. Agree 16 x 14 is too small. I will figure out drive ratio and see if that helps.
            OK. I note you did say BII with the 7.4. Earlier post was smaller engine. See if this page makes more sense showing a larger prop of 18.25 X 19
            I can't upload the whole file for your boat but if you go to the link I sent earlier you can get the whole book on your boat and find the correct engine and outdrive combo.
              A reputable prop shop would most likely be able to identify the prop.
              Here’s a prop selection calculator.
              https://www.mercurymarine.com/en/us/...or/#!/step-one
              "THE FIX"
              '93 2556
              • rbcooper
                rbcooper commented
                Or they should be able to measure the prop. This isn't rocket science they should be equipped to do this easily.
                RB Cooper
              • builderdude
                builderdude commented
                Fully agree
