Underwater Lighting-gctid350509
Blues46 wrote:
Has anyone tried these? http://"http://theliquidlite.com/" w.../> Liquid Lite
Seems like a simple install, without drilling any holes.
Exactly! Then I say to myself, what if it leaks, do the wires "twist" and break when I take it out? I probably worry too much!:hypnotysed:
My boat neighbor has a blue drain plug light (not sure if it's the same brand though) looked alright especially if you were paranoid to drill a hole in your boat. The brightness was okay. All in all it's not a bad deal. He is going to go with the real kind this spring as he wants to add more than one. But to attract fish and have the cool factor it should be fine.
I have 3x 50 watter halogen of my own design installed on Midnight Sun. I can tell you a 50 watt bulb gives out about 450 lumen and I have 3 which does a good job. 1 single 370 lumen (as they advertise) just is not going to cut it IMHO. Idea is very good but they need to increase that output to around 700 lumen to make it really attractive.
http://www.thefountainguys.com/
This is what I have mounted on my trim tabs. Two of the composite ones on each tab. I replace the 50 w bulbs with the blue and green 3 watt leds and they look cool and have not leaked in two years. I am thinking of trying one of the new stainless with lens. I drilled a hole on each side just above the water line, ran the wires to switches and to the battery. I just pulled one of the lens screws and drilled a hole into the L stiffner on the tab and made a small L stainless bracket and mounted it to the tab and to the yard stake swivel mountscrew hole. I bought the ones with the swivel mount and stake because the wires were long and did not have to splice. The hole drilled was the same size as the wire and sealed with silicone so it can easily be removed and replaced. And no holes under the waterline. I seen these on an old post several years ago and the cool part is I can angle the tabs down for fuish lighting.
Light conversion
LUMENS LED INCADESCENT
450 4-5 WATT 40 WATT
800 6-8 WATT 60 WATT
1,100 9-13 WATT 75 WATT
Rock
