Anchor watch alarms
    Anchor watch alarms
    What apps do you all use for anchor alarms? I’m feeling like it could hurt right. So far on windy nights I just listen and get up and check a couple of times.
    MV Kia Orana
    Currently Alameda CA
    myself, I dont use an app...I use the one that is in the gps unit.
    my lower helm gps is on all the time im on the boat so I can see immediately what my depth is, which is important to know if you've drifted while on the hook. (when in fresh water, its also nice to know the water temp with a glance at the screen)
    NU LIBERTE'
    Salem, OR
    5.7 OMC Cobra - 15.5x11 prop
    N2K equipped throughout..
      Similar to Centerline: I drop a “pin” on my plotter application (Navionics). Just unlock the phone to see if your where your supposed to be.
      "THE FIX"
      Misc. projects thread
        Anyone of them will work fine. I use the one in ISailor on m Phone when I go to bed at night so if I wake up I can check on our location. I also use “Anchor” because I can set my phone to remotely monitor my iPad when I go ashore. The iPad stays on the boat and sends out the location to my phone using cell service
        Partner in a 1999 4788
        Seattle, WA
          I am not sue if Rick still producing these anchor alarm. I have been using my alarm for 5 yrs and it has been flawless. This unit is stand along, can be carried into the bedroom or area of your choice to monitor potential drift. This unit doesn't rely on cell connectable.
          http://boathooked.com/articles/anchoralarm.html
          1992 4588 Twin 250 hp WO6-TI Hino
          12.5 kw Northern Light OM843NW2
          MMSI# 367650430
          FCC Call sign WDH 7669
            I use the anchor watch alarm that is built into my GPS plotter. I also use the Depth alarm on the same plotter, so two sources of data for the alarm.
            To make sure I get notified I have an external buzzer in the ceiling of the master berth.
              Ankor....its great!
