Well that sucks
    Well that sucks
    Crap! Click image for larger version
    "THE FIX"
    Misc. projects thread
    Why do you do that Dave?
    do you think it was a casting flaw or an interference issue putting stress on it?
      DB electric ?
        That’s not a modification you intended is it?
        • builderdude
          builderdude commented
          Yea, wanted to shave some weight off the ass end haha
        Yes that sucks
          Joon, yes DB starter only two seasons. Sounded strange earlier today so I tested it a few times with no more issues, came into Edmonds and moored up, wanted to check it out again. Hit the key and clunk grind not good and didn’t want to crank. Replaced it at the dock with a new “temporary” unit
          "THE FIX"
            Good question Mike. It looks like there was a dirty portion of the sheared section so I think it had a crack in the casting of the nose cone before it gave up. It never sounded strange until today.
            "THE FIX"
              I paint the starters 3-4 coats before installing.
              Send DB a note and a picture he might just send you a new starter.
              Hell if it helps tell him Chief Alen is your buddy, really he remembers good customers.
              • builderdude
                I’ll give them a call Chief
              Don’t think that is rebuildable.
              China?
              That was one part on my 2252 that I don’t think I would have been able to change without pulling the motor, so I had my starter rebuilt by a local company when I put a new Michigan motors engine in. Starter was easy to change when the engine was sitting on a crate in the back of my truck.
              Hopefully yours wasn’t to hard to get out.
              Esteban
              Vancouver, BC
                Guess we need to start maginfluxing these.
                  Major update to this starter issue:
                  The starters nose cone could potentially shear during cranking if a bit of resistance were to be applied, say a minimal amount of water finding its way into one of the cylinders.
                  Yep I think I’ve got a dribble coming in via the exhaust system that has exacerbated itself during this outing.
                  Oil didn’t look like normal oil and the evidence at the crank case vents at the flame arrestor.
                  Sucks X 2
ID:	448269Click image for larger version
ID:	448270Click image for larger version
                  "THE FIX"
                    That really really sucks. Are you certain it’s the exhaust and not a leak at the intake? Has the oil level increased?
                    whats the plan?
                      Mike, no loss of coolant as far as I could tell so I took that off the table but it's definitely still a possibility. The oil on the dip stick looks tainted. I could tell some moisture had been introduced into the crankcase and then I saw the vents at the flame arrestor. I then looked into the oil fill cap at the valve covers and saw the milky stuff and there's evidence of some "blow by" at the dip stick tube that I never had before but the oil level was dead on the mark still (I check the oil level every time I shut it down, touch it, smell it etc. ) After another attempt to start it last night on muffs she again struggled to turn over. For half a second it sounded like normal cranking then just quit like a piston coming up on a tiny amount of water. I released the key and tried again, same thing, sounded like normal cranking for a half second then stop. Tried a 3rd time and she cranked through it and fired up. My best guess is a trickle of raw water from the elbow or spacer joint running down into one of the center exhaust valves and getting in. I'm guessing I'll find low compression on one of them as well.
                      First thing on my list is pulling the plugs for a visual followed by cranking it overr to see what comes out. I'm anticipating moisture from at least one of them.
                      "THE FIX"
                        Yup, you have some water in the oil. I’d start at the risers, it doesn’t take much of a gap for just a bit to get into the cylinders. One thing for sure, you are catching it early. Once you have it fixed, SeaFoam in the oil and a change or two will clean it right up.
                          As I suspected a breach in the exhaust port side. I’ll put up a video when I remember how to do it
                          last pic shows the ss elbow surface. The dark area is where I belive it was getting through.
ID:	448419Click image for larger version
ID:	448420Click image for larger version
                          "THE FIX"
