Has anyone had a problem with the #1 battery going dead in two weeks of non use? Its a brand new interstate marine 800 cca starting battery. The #2 battery is usually fine. I think the CO detector and the auto bilge pump are hooked to this battery, but should they draw it down that fast? CO detector appears to be hard wired in with no plug, and how to unhook without cutting the wires, so I can eliminate it from any draw?
Jack
Jack
