Good Info on 3M 5200-gctid405093
    |-----------Original Message Follows------------|
    Subject = [P] Marine Contact Us
    Message = I have purchased 3M 5200 marine sealant on many occasions. It is
    very frustrating when I re-open a tube that cost me over $8 and find that the
    product has cured in the top of the tube and is almost impossible to get out.
    I don't feel this should be a one-time use product. I have very carefully
    cleaned the threads and the cap and secured the cap on the tube snuggly being
    carful not to over tighten the cap.
    The result is the same. I love your product and use it on my boat, but this
    issue needs to be resolved as I can not justify purchasing additional products
    if it becomes unusable after one use.
    RESPONSE FROM 3M
    Hello Thomas,
    Thank you for contacting 3M Marine.
    Unfortunately, there is no way to resolve this particular issue, other than buying only what you need for a single use. That is why we sell this product in 1 oz and 3 oz squeeze tubes as well as larger packages. Once the factory seals on the packaging are broken and the product is exposed to the atmosphere, it will cure in the tube. If you go much beyond the shelf life of these products, they will eventually cure in the tube without being opened.
    This is the nature of the beast. It is a consequence of the chemistry used, and not something that we intentionally design into the product. If we were able to make changes to eliminate this issue, the resulting product would not be 5200, or anything close to 5200.
    There are a couple of methods that can help extend the open life.´┐¢ ´┐¢ If you have access to a refrigerator that is dedicated to non-food use (do not store this product with food!), cooling this product to between 40 F and 32 F will nearly shut down the curing reaction. Packing the product in an airtight container with minimum dead airspace along with silica gel or other dessicants can also extend the open life.
    Regards,
    Scott S.
    3M Marine
    www.mmm.com/marine
    1-877-366-2746
    I am pretty sure it says on the bottle or package, that is begins to cure nomatter what after it is opened and it touches air. I am almost positive I read that somewhere on the package or bottle.
    On that note, I have goten 5200 to last for quiet some time before its shot.
      The other day I wanted to reuse this small tube and it was dried up at the cap. I couldn't budge it at all. So, I cut a small slit in the other end of the tube and was able to use what I needed.
      I figure I can keep adding slits to the tube until I run out of space thus using most of the tube over successive times of use.
        I keep mine in the refrigerator along with my super glue collection, in zip lock bags. Lasts a LONG time that way.
        " WET EVER "
        mmsi 338108404
        mmsi 338124956
          The fridge idea is great. I'll stick it in a zip-lock and put it in there.
          What I do for the dried end is screw in a #12 wood screw then pull it out. That usually gets the majority of the problem out of the tube.
            Next time I'll try the food saver vacuum bags and refrigerate.
              The wood screw is working for me quite well too.
              1992 4588
              Seadoo Wake 170
                Great idea. :arr
                  I have a product that I sell on the web called 2BLOK that will keep a tube of 5200 fresh for weeks. I have had a tube go as long as 6 months ! Yes 6 months. It was a little slow coming out of the tube but it did come out and I used it to set some tile in my laundry room. 2BLOK will keep Gorilla Glue fresh for years. This is not a scam or a joke. Go to 2BLOK.com to watch my how to video and to order. Hey 3m ?Wanna talk ?
                  The Dude
                  RESPONSE FROM 3M
                  Hello Thomas,
                  Regards,
                  Scott S.
                  3M Marine
                  www.mmm.com/marine
                  1-877-366-2746
                  _________________________________
                  Bayliner 3255 Avanti - 1989
                  OMC Cobra 5.7's
                  Refit in 2007
                  Photo album - Bayliner 3255 Avanti - 1989
                  __________________________________
                    3M 5200 is only needed to secure a hull to deck joint for boat builders. There is no need for casual boaters to ever use the stuff for caulking or sealing, yet I see time and time again boaters using it.
                    Perplexing...................
                    www.boatyardgm.com
                    www.pacificyachtimports.net
                    2002 Carver Voyager 57
                    "Making Waves"
                    3988 250 Hinos
                    "The Dark Side"
                    Alameda, California
                      You mean Ed shouldn't have 2 tubes of it sealing his transom shield ?
                      ............ Perplexing indeed
                      " WET EVER "
                      mmsi 338108404
                      mmsi 338124956
                        If you are using 5200 to turn the transom shield into a part of the hull, isn't that technically considered boat building?
                          +1
                          I do not think I have ever used it. I have one small tube in my tool bag that I keep just in case. I have found the 3200 that comes in a squeeze tube from Home Depot or Lowes lasts a long time in the tube. It seems to hold well it can be sanded and painted but still has some flex in it.
                            I wish they would make a 1/4oz tube. I like to use it for permanent attachment of things like holders for the brake line and wires on the trailer. Nothing else has ever held but 5200. I agree, there isn't much on a boat where you should use it. I have to admit, the plate I mounted my fire extinguisher to is attached with 5200 just because I mounted something to the trailer at the same time.....
                              I think many people confuse 3M 5200 with 3M Fast Cure 5200, thinking that one is simply a faster-setting version of the other. That isn't correct. 5200 Fast Cure is considered -by 3M- to be permanent, and 5200 is removable.
                              Use 3M's product selector and you'll find dozens of applications for 5200 that are not limited to hull/deck joints.
                              As an aside, it's interesting to see that this year-old dead thread was resurrected by a spammer.
