Got the engine and entire outdrive assembly (inside and out) removed from my '83 Contessa Sunbridge. Due to some dampness/sponginess, I need to repair the lower part of the transom which will include 'glassing over the stock transom drain hole. Once done, rather than drilling out the transom drain hole and reinstalling the stock drain, which is basically a garboard drain assembly (2" brass flange w/1/2" brass plug), I rather install a 2 ┬╝ " (transom thickness) drain tube w/plug, but my search of the net has come short. Anybody know of a source or a possible work around? Thnx.
Wayne
Wayne
