Macerator-gctid403813
    I hit the switch and heard nothing, just learning the boat but am I doing something wrong. I know that there is nothing really in the tank, but should I hear something?
    A little more boat info and I'm sure you will get some more suggestions for help.
        Usually there are two switches. You have hold them both on at the same time.
        Cheers
        John McLellan White Rock BC
        "Halifax Jack"
        1999 2855 383 stroker BII
        MMSI 316004337
          i only see one just behind the throttle
            OK all good, pulled the switch found both wires off and wrapped in electrical tape. Unwrapped them and found one had the female spade connector broken off and the remnants were still on the switch. Replaced the connector and reattached to the switch, still nothing. Went into engine bay and found the ground wire to the pump was cut, no idea why initially then I thought it may have been due to the broken spade connector flopping around in the hull and the previous owner not knowing what to do to ensure the pump did inadvertanly start up. Reconnected it and with a tank full of water from the hose away she went. Works fine and the switch functions perfectly.
            THE POOPER PUMP PUMPED.:worth
              My Esc Key wrote:
              ... it may have been due to the broken spade connector flopping around in the hull and the previous owner not knowing what to do to ensure the pump did inadvertanly start up.
              You didn't mention where you are, but it could be he didn't wanna pay the fine for having a macerator hooked up?
              iBoatNW
                I am in Ontario, is that an issue?
                  It could be if you are on one of the Great Lakes. Here in the states it is illegal to have a working macerator on a boat in the American waters of the great lakes. When my 3055 was inspected by the CG some years ago that is one of the things they checked. My macerator wires were cut at both the switches and the pump by the dealer prior to my taking delivery.
                  Rick Grew
                  2022 Tahoe T-16
                  2004 Past Commodore
                    Having a operational macerator in Ontario is a 360 dollar fine using it and getting caught would be alot more . The wires are cut on purpose and should not be reconnected .
                      so I crawled around in there for nothing? So can I get away with unplugging the switch?
                        I would follow their advice and disable it by cutting and securing the wires.
                        iBoatNW
                          Never heard of anyone being boarded and having it checked. But you never know. Use a pumpout station at most marinas. Dumping raw sewage overboard sounds kinda gross ops
                            The fish do it every day
                              maybe in the cold north of winterpeg but ontario fish know better LOL
