Lost electrical power - Bayliner 2452 year 1995
    Hi guys,
    I am starting engine every weekend even when I am not going out. So today I tried to start the engine and lost power. Does anybody know where the main fuse is at Bayliner 2452 year 1995?
    I have some fuses on cables going out of main switch, then a fuse box in the cabin and one big one besides house batteries. Check attached pictures please.
    Jan
    Vancouver, BC, Canada
    Bayliner Classic 2452 (year 1995)
    Mercruiser 5L, Alpha One
    sorry, this post got published before I was able to say:
    Thank you very much for your help, guys!!!
    Jan
      Top of the engine, red button.
      Everything runs through that breaker.
      4788 LISAS WAY
      SEWARD, ALASKA
        Looks like this. Probably starboard side of engine, just forward of the exhaust manifold. Also did you loose everything as in cabin lights etc. and while cranking the engine? Check your battery cable connections, both possitives and negatives and at both ends. Click image for larger version  Name:	image.jpeg Views:	1 Size:	5.1 KB ID:	413859
        "THE FIX"
        Misc. projects thread
          Hi guys,
          Thank you for your answers!!! I had my genius friend with me on the boat today, we checked all cables, fuses, batteries, all good. But did not notice that magic main breaker.
          Going to check tomorrow again!
          RE: Also did you loose everything as in cabin lights etc. and while cranking the engine
          - Yes, no lights, no power what so ever! Just one crank, Puffffffffff, silent, dark, cold. Mind you, it was -8 few days ago, but I do have a heater in the engine bilge and in the cabin as well
          Both still working - shore power.
          Appreciate your help a lot, gents!~!!
          Jan
          Jan
            There is a fuse on the starter soleniod that supplies power to the alternator, engine breaker mentioned above and helm. However neither this fuse nor the engine breaker power cabin lights.
            To lose engine power and cabin lights one of the following must be bad; batteries, corroded or lose battery cables including the return (ground), battery switch itself.
              - Thank you, Mike... what could happened, bilge blower was running, cranked the engine once and lost all the power? Sure feels like a fuse somewhere...
              Jan
                Jan, there is no one fuse that provides power to the engine and cabin lights. Really sounds like a loose corroded battery cable. The act of cranking the engine draws lots of current and a loose connection will heat up and become highly resistive. This now causes a large voltage drop and not enough power is now available to operate. BTY many have had the Perko battery switch go bad just like this.
                  Just for giggles check the wiring harness barrel connection.
                  "THE FIX"
                    Mike, perhaps your boat is different, but both my 2859’s and my 2452 were wired where all power went through that breaker on the engine. All DC power to the cabin DC fuse block came directly from that breaker. Then a fuse off of that main fuse block went to the ignition system.
                    4788 LISAS WAY
                    SEWARD, ALASKA
                    • builderdude
                      builderdude commented
                      I agree, just looked at some schematics to verify. Breaker protects red/purple going to the hull harness.
                      I thought the block fuse at the starter lug was to protect against over charge current from the alternator.
                    • Nauti_Mike
                      Nauti_Mike commented
                      Dave I disagree, the diagram shows engine power and the mating harness only goes to the helm gauges and ignition switch but not to the fuse block at the helm. At least the helm diagram does not show a tap to fuse block nor could Mercruiser know what load a boat builder would need.
                    • ksanders
                      ksanders commented
                      What Bayliner did was to use that wire to feed the main fuse block which on my 2452 and both 2859’s was behind the helm.
                      I traced this out on both model boasts and am 100% confident in that.
                      I also added a house bank to both boat models, and have a wasy way to do that, eliminating what I consider to be a design flaw in the Bayliner electrical system, if anybody is interested.
                    Breaker #7 protects red/purple to hull harness.
                    "THE FIX"
                      The block fuse at the starter lug:
                      I know this has been questioned before, but I've seen one schematic showing both orange and red wires protected by the block fuse and one schematic showing just the orange wire protected yet the schematic I posted doesn't show it at all.
                      Don't know what to think, I actually don't have that block fuse
                      "THE FIX"
                        Kevin, Dave
                        my understanding is is that all engine/helm power is feed by the fuse on the starter and the engine breaker but not any boat power. The fuse and breaker are part of the Mercruiser wiring harness and the rest of the boat items lights, horn, accessories are feed from the battery switch.
                        Mercruiser would not know how to size the breaker for all boat sizes and power needs they only are protecting their electrical.
                          Jan measure to see if 12V is present at both sides of the fuse on the starter. If no power go measure at the battery switch.
                          Have you checked the battery cables for corrosion and ensuring ensuring they are tight including the return on the back of the engine?
                            If there is a 90AMP square main fuse at the starter, everything goes thru the main fuse.
                            • Nauti_Mike
                              The OP has a 1995 so it should have the fuse. Older models did not.
