3055 cooler size for under seat
    May seem a bit odd this question but what size coolers fits in the gap underneath the rear seating of the bayliner 3055 ? My bracket has deteriorated so need it prodded up. Looking at a Coleman of some sorts. Anyone have any wallmart links to the correct size would be awesome!
    If you're talking about the factory spot on the st/bd side in the engine cover then I use the 35 qt Engel.
    I use some white 3/4" high density closed cell packing foam under it and on the sides to give a snug fit and provide additional insulation from the engine heat.
    Hope that helps.
    The Engel 35 DeepBlue Roto-Molded High-Performance Cooler is the ultra-portable model, small enough to easily carry while still packing in up to 20 cans.
    Sea Venture
    2000 3055, 5.7/B2, 18x23" props
    Cruising the PNW and beyond.
    DIYC, Riverhouse Marina
    MMSI 316029971
    Kirk
    Drinks well with others.
      Lovely thank you for your reply! And that’s exactly what I asking :-)
        Mine came with a 54 quart Igloo cooler. Hope that is somewhat helpful.
        Rick Grew
        2022 Tahoe T-16
        2004 Past Commodore
          Does that fit snug?
            Originally posted by Medders View Post
            Does that fit snug?
            Yes. You have to lift up the cushion above the cooler space then slide the cooler into the recesses cooler area. It is a very snug fit.
            Rick Grew
            2022 Tahoe T-16
            2004 Past Commodore
            • SprinterX
              SprinterX commented
              Same with my Engel and the foam.
