towing can i tow my 2859 with my 2016 ford f 150
    need help
    What is the weight of the boat and trailer together? Does that weight exceed the manufactures tow rating? You will also want to make sure that the trailer brakes are working correctly. Your load will outweigh your truck so you don't want to try and stop it with the truck brakes only.
      Who knows; what engine, transmission? does it have a tow package. What is the weight of the boat, trailer, and gear onboard?
        It could probably be done but personally I'd think an f 150 would be a bit on the lite side for a trailered 28.
          I agree with builderdude... a 150 is too light weight, but it can be done. to do it safely all depends on how far and how fast you plan to go.. in addition, if you plan to launch and retrieve at a ramp. you may find problems because of the slope of the ramp.
          ive seen people who couldnt pull their boat up the ramp due to not enough traction, and others with not enough power.... and others who lost control when backing down the ramp.
          an F150 usually has taller gearing, and is only set up for light towing.... pulling a 28 is considered heavy towing.
          add together, the manufactures dry weight of the boat, with another 2000lbs for the weight of the trailer, and another 1500-2000lbs for fuel, water and gear... 13,000 to 14,000 is not unreasonable for that boat...
          bayliner says my 2556 has a dry weight of 5.600lbs. but setting on its trailer, uncoupled from the hitch of the truck so it also weighs the tongue weight, loaded and ready to cruise, it weighs 11.300lbs as told by the certified scales... this is what is considered the towing weight... you can do the math for your 28.
          NU LIBERTE'
          Salem, OR
          5.7 OMC Cobra - 15.5x11 prop
          N2K equipped throughout..
            Don’t know how Bayliner figures their dry weights, but in my experience they are always less than what the rig eventually weighs when you get to the scale. I had an older 2755 that per Bayliner was supposed to be around 5800# as I recall. On the scales with an aluminum tri axle trailer, it was close to 9500. I figured 1500 for the trailer so IMO the boat was just about 8000 with minimal gas and gear onboard. Just my $.02.
            I am currently towing a 2005 Bayliner 275 with a Toyota Tundra SR5 which is about all that truck is capable of handling. I don’t think you should consider towing a 28 footer with an F150 unless you are only going a few blocks.
            1990 2755 - sold
            2005 275 - sold (now boatless)
            • builderdude
              builderdude commented
              My best guess would be BL probably listed the dry weight of the base model boat without any additional options like big block engine upgrade, closed cooling, water heater, holding tank, refrigerator, house batteries etc. etc.
            My 2859 weighed 10,550 on the trailer (light gear load-out). No F-150 has a GVWR high enough to do it legally (or safely). Even an F-250 takes some patience and special consideration. It'll eat your lunch if you're not careful.
            iBoatNW
              I own a 2859 and she is heavy the trailer is a 3 axel and heavy, so I would be very hesitant to hock a 150 up but in the parking lot. loaded Picture of my set up.
                It depends on many things.
                How far are you towing?
                Weights of truck and boat?
                Does the trailer have brakes/sway bars?
                I used to tow my 26 foot Reneill with my Durango no problem.
                Joel
                1987 3818 Hino 175
                "Knotty Girl"
                Prince Rupert B.C.
                  I would not tow that with a half ton. Not a chance. IF it were just to pull it out of the water and park it nearby, maybe, but nothing past that. Too light duty. Brakes, suspension is the problem. Power wise its probably fine but thats not the issue.
                  if something happens whether its your fault or not. An investigation would put you at fault for overloading the truck and render your insurance void.
                  Doug
                  496 big block - Bravo ll leg
                  The Doghouse
                  Prince George BC
                    It depends on your truck setup and the weight of the boat. Ford is advertising 12,200 lbs for a 2017 f150 with a 3.5 eco boost (11,000 lbs for a 5.0 liter). As long as the load weighs less than that you are legal. Will it tow well? Who knows ! Obviously a heavier rated truck will tow better but if you are not planning to go long distances my guess is that you should be okay.
                    Getting moving is the easy part, stopping .. now that is a whole other story. The trailer needs to have trailer brakes with that sort of weight.
                    As long as you have the right setup within the legal parameters then I don’t see any reason to tell you that you cannot do it.
                    2014 Double Eagle 176EXL. But we are not done with Bayliner yet…this is just to get us to and from our cottage in the Gulf Islands.
                      I had a 2452 and towed it to Ucluelet in my 1500 Suburban. I vowed never to do that again. Next year I towed it with a 2500 Diesel and it was night and day. Now I have a 289 and the 2500 Diesel tows it beautifully even over mountain passes. Since the 2452 is much smaller than the 2859, I'd only consider very limited in town and slow towing if only very occasionally.
                        The help you're looking for is... Don't do it. Sure, anything is possible, but get the right tool for the job. I had a 289 on my current 2800 lb. trailer, and it weighed @ 12,000 lbs. I pulled it with an F-250 diesel, no problem. Towing speeds and distances do not dictate towing ability or safety. And welcome to the BOC!
                        Jeff & Tara (And Hobie too)
                        Lake Havasu City, AZ
                        And 13 others...
                          The F150 has a tow mode on the tranny, it gears it down as well as computer changes, short distances should not be an issue, I would not tow it on the freeway though unless in a slow lane.
                          With a 3.5 I would be hesitant. I have a 2011 F150 5.0 with a factory hitch and trailer tow mode tranny.
                          Speed while towing is an issue.
                            The half ton has suspension that is too soft and tires meant for a comfortable ride. You can get the rig up to speed, but it will be very scary in a crosswind or going DOWN a hill.
                            My suggestion goes along with the others; don't do it.
                            2007 Discovery 246
                            300mpi BIII
                            Welcome island Lake Superior
