1987 bayliner capri 2.3 ford w/omc cobra, lots of questions?-gctid400453
    Have you done a tuneup? I'd bet it needs one (my 89 2.3L needed one because the previous owner didn't think it needed on in 12 years).
    Also, make sure timing is dead on. If it's off, expect backfire, misfire, etc
    Re stalling, there is a shift interrupt switch that helps to make shifting smoother, it sounds like the switch is stalling the engine when shifting. This could be a cable adjustment issue.
  • Chief_Alen
    Welcome aboard !
    I strongly suggest you buy a manual. There may be a free d/l here :
    http://boatinfo.no/lib/library.html
    Ok here's another d/l... best write up on cobra drives how to adjust them etc. read and re-read it and print out a hardcopy you will need it when working on the new lower cable i think you need . See i think your lower cable went.
    http://www.hastings.org/%7Estuart/cobra/kw-shift.html
    You trim... hmmm... maybe the solenoid went or the rams are frozen or rusted. Or air is trapped in the lines.
  • 1987 bayliner capri 2.3 ford w/omc cobra, lots of questions?-gctid400453
    Hi my name is Chris,
    I recently traded a hovercraft for a 87 bayliner capri it has the 2.3 ford, I know nothing of this boat,
    1. When i push the toggle on the tilt/trim the solenoids Just click,whats that mean?
    2. The guy who had this before me said when he moves the throttle Forward the motor dies, what could be wrong?
    More questions to come,
