16(39) Element speed sensor location?
    The speedometer on my 16' Element stopped working yesterday. I suspect that the speedo sensor became clogged with river debris. Where is the speedo sensor located on my boat?
    Thanks,
    Kim
    I should have been a pair of ragged claws
    Scuttling across the floors of silent seas.
    It should be a small hole in the leading edge of the lower unit, below the anti-cavitation plate and above the "bullet." It can be cleaned with a small wire or a small drill bit.
    Frankly, while I try to keep my speedos properly functuioning due to my OCD, there are a zillion GPS apps for phones, and cheap handheld GPS's, that will be more accurate and more reliable. And the Mercury Vesselview Mobile Module (~$250) and app (free) is AWESOME.
