I have a 1980 Bayliner Saratoga with a 350 in it not sure if the motor is going to work out so my question is I got a friend of mine who has a 94 GMC 2500 with a 350 with around 160,000 miles would this block and engine work would I have to change the heads and put my heads on his motor what would it take and will it even work thanks for all
Will this motor work
IMHO, since marine engines get a fraction of the serviceable life of a vehicle engine, do solely on the tremendous expense of having to rebuild it sooner than I would have to, I'd want to put something that I know will last the longest ...before I'd have to do it again.
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
"Hicks" post=828717 wrote:
This is my thought not knowing... is that I can pull the engine out of the boat I got and rebuild for around $600 that's me doing it myself which I have no problem doing but I could have bought this truck with this motor for 400 bucks so I didn't know what the right way to go was
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
"Hicks" post=828722 wrote:
Also just want to let everybody know that I'm new to this big boat inboard sterndrive stuff I've only had flat bottom boats with Outboards and bass boats and CC's all my life so I'm probably going to ask a bunch of stupid questions so in the future you'll know why LOL
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
A marine engine has a different cam. If in salt the water pump will need to be changed. Also the core plugs (freeze plugs). I think pistons are different.
Carb, distributer, starter, alternator need to be marine.
Likely forgot something but I don't think you would get good service from that engine.
Doug
Camshaft, pistons, valve seats, head gasket, frost plugs, oil pan (and I am sure there is a bunch of stuff that I have forgotten) are all different on a marine engine vs a truck engine. Of course all the peripherals need to be marine too...starter, alternator etc. Etc. Etc. If all you are looking to get is most of a season out of the truck engine then your expectations might be met. Who knows, maybe you will even get a full season out of a truck motor in your boat. Don't expect much more than that though. If you want to turn it into a marine engine that will last, you will be far cheaper off putting a proper marine engine.
Trust me on this one, I have a Dead Chevy truck motor in my boat that made it almost 1 1/2 gently used seasons since being purchased brand new From the GM dealership.
Truck motors and boats simply do not mix !!
2014 Double Eagle 176EXL. But we are not done with Bayliner yet…this is just to get us to and from our cottage in the Gulf Islands.
If the engine is raw water cooled and was used in salt water I would not rebuild it as the water passages have been corroding and loosing wall thickness. If this is the case I would either buy a marine rebuilt long block or have one built by a shop that is expierence in building marine engines.
and then on the other hand, there have been a LOT of DIYers who have taken a used automotive engine, fitted it with the proper cam (without rebuilding it) and have gotten a good service life from it.... more than a few years have gone by, but at one time this was fairly common. maybe its how one uses or abuses the engine that is the difference, but a dependable conversion is possible.
the heads and cam are the 2 major components that need to be "Marine" to stand up to the service a marine engine is subject to. and for saltwater use, the freeze plugs should be brass or preferably stainless steel for longevity.
the peripherals such as alt, carb, starter, ect are also a concern, and absolutely if the engine is in an enclosed space.
some of the newer engine are not a candidate for this simple conversion... nor am I advocating that just anyone should try it with an older engine, but it has been done successfully many times.
but these success's were almost always made by people who were reasonably good mechanics who knew the differences between an automobile engine and a marinized engine... and knew how the engine was going to be used afterwards.
if one looks around, he will find there are a lot of used boat engines that could be installed, rather than attempting a questionable conversion on a truck engine.
we ALL would prefer new and fresh, but it is my solid opinion that any engine that has several hundred hours on it is a used engine, but that does NOT mean its an undependable or wore out engine...
every time I start my motor that was dependable last time I used it, when I start it today, its just another "used" motor that im hoping will be just as dependable this trip out, but I dont really know that it will be.... and the next time I take it out, it will be more "used" than it was the last time.... so used engines shouldnt be discounted when your working on a budget, BUT, an internal inspection of the engine will give a good indication of how much life should be left in it, if cared for properly... for only the price of a gasket kit.
but take nothing for granted when it comes to anything about a boat, other than they arent cheap toys..
NU LIBERTE'
Salem, OR
5.7 OMC Cobra - 15.5x11 prop
N2K equipped throughout..
"Centerline2" post=828778 wrote:
and then on the other hand, there have been a LOT of DIYers who have taken a used automotive engine, fitted it with the proper cam and have gotten a good service life from it.... more than a few years have gone by, but at one time this was fairly common. maybe its how one uses or abuses the engine that is the difference, but a dependable conversion is possible.
the peripherals such as alt, carb, starter, ect are also a concern, but mainly if the engine is in an enclosed space.
there are a lot of used boat engines around, if one looks, that could be installed , rather than attempting a questionable conversion on a truck engine.
we ALL would prefer new and fresh, but it is my solid opinion that any engine that has several hundred hours on it is a used engine, but that does NOT mean its an undependable engine...
every time I start my motor that was dependable last time I used it, when I start it today, its just another used motor that im hoping will be just as dependable this trip out, but I dont really know that it will be.... and the next time I take it out, it will be more used than it was the last time.... so used engines shouldnt be discounted when your working on a budget, BUT, an internal inspection of the engine will give a good indication of how much life should be left in it, if cared for properly... for only the price of a gasket kit.
