From the other thread, I wrote:
Over-inflate trailer tires? I just did an overhaul on my trailer tires. I noticed that the wear is very inconsistent, and to me, extreme. I've towed trailers all my life and never seen the kind of wear, though this trailer is carrying the most the weight I've ever towed. I also have a torsion system, so I understand that wear can be different between tires.
You guys are saying that over-inflating them will make them last longer? I keep mine between 60 and 65lbs due to some advice I received on here, and based on what is printed on the sidewall.
http://www.baylinerownersclub.org/in...-of-boc#576262
Here is the right rear trailer tire wear. This one was the worst, so I moved it to the spare and put the 'new' spare on. The other side rear tire is almost as bad. The two front tires are worn, but still have plenty of tread.
The most wear is on the outside and on the rear tires.
These were pretty much new when we bought the boat and trailer in July or 2014, and considering I travel 17 miles and back in one direction (to PA Haven Marina) and 5 miles each way to JWM, that equates to a total of about 1,000 miles. This amount of wear seems very extreme. I will also say that I have never had a torsion trailer, so I have no idea if this is normal. I also thought that putting too much air in the tires would make the boat ride too rough.
Thoughts? Do I need to increase the tire pressure? If so, to what?
I should also add that I switched the drum brakes to discs, and replaced the bearings and races. When I just did the maintenance, the grease is good, no water intrusion and the bearings, races, seals and spindles are like new.
