I have a 1980 Bayliner Saratoga offshore how do I know what motor I have it came with a diesel 350 or 305 it is gas so I know it is one of the two 350 or 305
What motor do I have
Some photos might be helpful here.
Greg
Newport, Oregon
South Beach Marina
Why you pulling the heads?? Do you think there may be issues with the valves, seats or head gaskets etc?? If so has a compression, leak down and cooling system pressure test been performed to verify the issues your having?
Okay here's the scoop on this boat 9 years ago the heads were completely rebuilt and redone .. then this boat was parked in dry storage for 9 years and was never started from what I understand there was no water in it there was no fuel in any of fuel lines we took it down to the heads and just as I said they look brand-new they didn't even have any oil in them the oil in the oil pan looks good but it will not turn over it is stuck I'm guessing that the Rings are stuck ...
I see. After 9 years, yes the rings are likely rusted to the cylinder wall.
You sure it ain't the drive or gimbal frozen?
What drive ?
Fill it to the brim with desiel or kero.
Pickle it for a few days.
Drain, and change the filter. Add oil one quart shy and add a quart of at fluid.
Rock the engine crank back and forth might free it up. Try to use the flywheel do not use the crank bolt, snap that you will be in a world of hurt.
Maybe removing the plugs and shooting oil in the holes may help.
What drive ?
