Hi all. Our 325's frige is having trouble freezing the ice cubes. Compressor runs all the time and setting on max cold. We have been told that these usually can't be repaired and it''s best to replace. Has anyone else had this problem? Thanks, Griff.
Norcold DE0041R cabin frige on the way out.-gctid828084
You can have the frig coolant purged and re-filled, have them add a very slight amount of coolant over the specs-not much.
My full size Norcold had 1/4 oz more than specified and I can keep ice cream in the freezer at less than max cool.
As long as the compressor is working this should work.
If no fill valve is present they can add a piercing valve, very easy to do.
