Cavitation-gctid827401
Maybe you could call the manufacturer on that one. They likely have a technical help department. Please let the rest of us know what they say about it.
Greg
Newport, Oregon
South Beach Marina
Interesting.... My outboard didn't have anything on the aft edge and I don't remember any cavitation issues except when I'd trim up for top speed. I'd take it up till cavitation started then thumb back down till it went away. I'll have a look at the 2655 in a bit. It's been converted to a stainless prop and came with two additional props but don't think there was any ring on them. Hasn't made it to water yet but I'll looking and listening..... Does it sound different? Can you "feel" a difference?
I always associated cavitation with "over speeding", reversing rotation still under fwd motion, bent blades, not enough fluid surrounding the prop (trimmed too high) or disruption of fluids either at or just before crossing the plane of the blades, or rough choppy water that is aeriated. I've not given much thought to fluid past the blades since forward motion in most cases I'd think would prevent "downstream" fluid from circulating back fwd. like with some submerged pumps where the fluid is mainly static around the pump/ impeller.
I'd imagine though that the missing ring would/ could cause turbulence as the water rushes past. That has me pondering now if the ring's purpose is to "streamline" that water, reducing churning and leaving a cleaner center area in the wake "cone" and could that water now be causing a hydrodynamic condition between the stern area and that larger mass of water passing under it......I guess a form of cavitation. I tend to put way too much thought into things I don't have a lot of experience with but hopefully someone will pick up on something above and give you a better (and much shorter) reply......
Sold:
Mariner 150
Towing with:
Near High Rock Lake, N.C.
The prop had the ring which can be seen in pic below from just prior to purchase. Never hit anything, but when we raised the boat (on lift) after second trip noticed it was missing. Haven't really heard it cavitating (except for once when we went WOT to get on plane and it was, but the outdrive was still raised up a bit and tabs weren't down. Put the OD and tabs all the way down and it went up on plane without further cavitational sounds).
Just wondering if it would cause cavitation or "bite" issues when running. Will try calling MERC as it is original prop. Just thought someone on the forum may know what the "flair" does or if it has an effect on the water or exhaust. Am thinking it may have been done as a weight reduction thing by MFGs.
2004 Monterey 282 Cruiser
Twin Volvo Penta 5.0GXi-E
SX-M 1.6gr Outdrives
Docks @ Punta Gorda, Florida
I had a 1993 20' Sea Ray bow rider 4.3 with an Alpha drive that I bought a new prop for and within a week the diffuser ring fell off in the water and the boat started experiencing prop blow out in turns. The place I bought the prop from replaced it and the issue went away.
Edit: The flare probably pushes some water aside to reduce the pressure the exhaust gases experience. Basically carving out enough volume in the water behind it to account for the volume of water + exhaust. Without it, the engine probably encounters more backpressure on the exhaust ports due to water pressure increasing rapidly with depth.
I got really curious about this, so I called Mercury Marine. First, they told me this is not likely to be an actual Mercury prop as the lip is cast into the hub on their props. The purpose of the lip is to increase "lift" of the propeller blades. If it is missing it will cause some cavitation at higher prop speeds. So if you do a lot of cruising it would be best to replace the prop. They also said, if you should find a Mercury part number on it please contact them as they would like to know about it.
Greg
Newport, Oregon
South Beach Marina
I know this is an old post (of mine), but finally after several months of holidays and travel I was able to get back to work on several issues. LSS - had a successful outing yesterday, and was able to plane quickly and run up to WOT without any overheating, fuel or oil pressure issues. All is well in that department now. However, after being on the water for a couple of hours, most between 28-3400rpm, we were cruising along and I opened it up again to about 4000rpm. All was good for about 5 seconds then the rpms went up and the boat slowed (the butt fell off plane). I throttled back to about 2500rpm and the boat didn't fell as if it were making any headway. I dropped it to neutral and let it sit for about 10 seconds, also ensuring the sterndrive was fully trimmed down in case I had inadvertently pressed against the trim button by accident. I then went into forward gear again and all seemed OK. Went right back up on plane and ran OK at 2800rmp back to the harbor inlet.
The prop is a Black Max aluminum 15.25 X 15P. Curious if the Black Max hub can slip like that and then seem OK after a very short rest. The prop did lose the rear diffuser ring first trip after purchase, and the boat has done this twice before. Is there a difference between a prop hub spinning or the drive coupler going bad?
Pics showing current status after I finally got it off the boat today. I cant see any breaks in the rubber, but not sure what to look for in this style hub.
Appreciate thoughts/feedback.
I would use a center punch and mark the outer hub of the prop to one of the groves of the inner hub. run the boat till the event happens again and see if the two are still in alignment.
If you don't see or smell burnt rubber behind the engine I doubt the coupler slipped.1997 Maxum 2400 SCR 5.7LX Bravo II
Originally posted by Nauti_Mike View PostI would use a center punch and mark the outer hub of the prop to one of the groves of the inner hub. run the boat till the event happens again and see if the two are still in alignment.
I didn't smell anything yesterday when it happened, but also didn't think to stick my head down there when it happened. I was in the area once home checking all fluids to ensure no losses during the trip, but didn't smell anything like burned rubber then. As you say, I'll see what happens in the future.
For some reason, Bayliner didn't think it necessary to connect up the sterndrive tilt/trim gauge system on the 98 2655, so I'm still wondering if I have accidently hit the "trailer" switch with my arm while driving, and wasn't aware of it. That is a future project as the "depth finder" they put in the dash is useless and provides me a hole space to add a TT gauge.
Thanks for the feedback......2004 Monterey 282 Cruiser
