So today I added Marine Stabil and let it run for about 10 minutes, then I sprayed the carburetor and each cylinder with fogger spray. I drained the engine of all water and filled it back up with antifreeze. Cleaned the bilge out and made sure it was dry and then I drained and changed the outdrive gear lube and finally vacuumed and cleaned the vinyl before putting the canvas top on. I waited on the oil change because I'd rather do it fresh in the spring. Also haven't removed the battery just yet, but it'll go on the tender for the winter. Anything else?
