Hey guys near the end of the Boating season over here in New York just curious what everybody's opinion is on the best gas stabilizer.
GAS STABILIZERS-gctid827027
I have used many different brands, they all seem to work well. Is the fuel in your area ethanol free?
Make sure after adding the fuel stabilizer you run the engine to ensure the stabilizer has made it's way through the whole fuel system, then change your oil and do the rest of your layup.
Joel
1987 3818 Hino 175
"Knotty Girl"
Prince Rupert B.C.
I agree with Joel, and will say that there is no substitute for Non-Ethanol gasoline.
As Joel suggests, operate the engine after the stabilizer has been thoroughly mixed with the fuel.
** You can also empty and re-fill your fuel filter cartridge with an oil-enriched fuel mixture and operate the engine until the mixture has reached the fuel delivery system.
Keep in mind that we Fog carbureted engines only and that we DO NOT Fog a TBI or FI or MPI system.
For those systems, use the above ** method.
"Norton Rider" post=827064 wrote:
I use non-ethanol gas with Sta-Bil brand stabilizer in my outboards, lawn equipment, and my motorcycles. I've never had any issues when I recommission them in the spring.
in the past 10 years since using these products religiously, I have saved thousands of dollars in repair bills. at $150-250 per visit to the repair shop it adds up quick when a person has lots of equipment and not enough time to work on it themselves...
NU LIBERTE'
Salem, OR
5.7 OMC Cobra - 15.5x11 prop
N2K equipped throughout..
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
Here on Long Island, NY I use E-10 gas and choose to run Startron Gas stabilizer continuously throughout the boating season. That way there's no question about getting treated fuel to the engine when winterizing. I used to be OCD about storing the boat with 3/4 tank or more, but not any more....half a tank is fine.
Ted
2005 288 Command Bridge
350 Mag MPI / BRAVO III
Every Day Is Saturday
Couldn't resist. Back to the thread. :silly:
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
Incidentally, you can find the locations of road and marine gas stations with non-ethanol fuel here:
https://www.pure-gas.org/
2013 Boston Whaler 130 SS
Isla Verde, PR
I just bought the Stabil Marine 360 (blueish color) at Walmart for $8. Honestly not sure there's any real difference between that and regular Stabil, but for $8 I figured why not, don't be cheap.
I also added it, let the boat run about 10minutes, then fogged the carburetor and even fogged each cylinder through the spark plug holes.
2001 Bayliner Capri 1950 CL
"Doubled50" post=827127 wrote:
.....then fogged the carburetor and even fogged each cylinder through the spark plug holes.
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
Isla Verde, PR
[attachment]41864 wrote:
D0911707-9C36-49DC-9A42-E7BBE0FA8C63.jpeg[/attachment]
