Extra Wire Perhaps?-gctid825622
Yep, should plug into the electric choke somewhere near the other wire
Could it be the four barrel carbs use the spade gnd wire? Because there is a ground wire on the choke already - one using an eye lug attached to the screw top right. Hasn't ever affected the running - choke seems to work well, Was just curious - extra parts and all that make one go Hmmmmmmmmm.....
Thanks guys for the feedback.
2004 Monterey 282 Cruiser
Twin Volvo Penta 5.0GXi-E
SX-M 1.6gr Outdrives
Docks @ Punta Gorda, Florida
some chokes are grounded internally thru the the throttle body, but not all of them. maybe the choke was replaced at some point and that is for the old two wire set up... if you dont have another spade terminal on the choke cover and the choke is working fine as it is, you dont need to worry about the wire anymore.
NU LIBERTE'
Salem, OR
5.7 OMC Cobra - 15.5x11 prop
N2K equipped throughout..
