PLEASE HELP SUPPORT OUR SITE
I have a 2011 2855. What I do is I take my compressor and insert the compressor hose into the hull outlet (located on the starboard side of my boat) and blow the line out with about 20lb pressure. Then I open the filter area, suck out the water, and pour in the pink stuff.
I first drain the strainer then get a liquid hand pump and stick one hose end in a gallon of pink antifreeze and the other into the ac water outlet on the side of the boat and pump the antifreeze through the system until the pink is coming out under the boat. you may need to use a rag or something to plug around the hose in the ac water outlet.
