I'm refinishing the teak cap around the cockpit of my '88 3818. I want to remove the rear-most cleats but I'm fairly sure there is some sort of backing plate or at least a nut and washer. Just turning the Phillips head screw does nothing but spin.
Is there some sort of access under the padding around the inside of the cockpit or so I have to remove the engine vents to get to it?
Thanks for any advice you can give!
