on the engine of my '89 2556 the low oil sensor and the high temp sensor is a light blue wire, but there is only one light blue wire at my dash/helm and it goes to the oil pressure gauge, which is supposed to be independent of the warning system..
I have a detailed schematic of the boat wiring, but not the engine wiring, nor does the warning buzzer or the wire show on the boat wiring schematic.
is the warning buzzer supposed to be at the helm or is it found in some other location?.. it doesnt work when I ground the wire at the engine so it isnt working, and if I only knew where to look and what color wire to look for I could fix it.
also, does anyone have a detailed engine wiring schematic they could share? Thanks
