Homemade Trailer tongue stand advice-gctid824581
    Made this with a 4x4 and some scraps but it still feels shaky. I don't think it'll wobble off, but I wanted to take the weight off my wheel. Any ideas? What do you guys do?
    2001 Bayliner Capri 1950 CL
    Concrete blocks, thats what I use when I wont to block the tongue!
    Otherwise I leave it on the tongue jack!
    Don
    1988 Bayliner 2455 (sold)
    1976 Tahiti 16.5 I/O (sold)
      Prior owner of our lake boat had a stand made up that I now own. It has a 12" square steel plate at the bottom with a 2.5" diameter steel pipe welded to the base. At the top of the pipe he welded a U that the trailer tongue slots into. The U has a steel pin that then fits in over the top of the trailer so you can lock it into place. The stand raises the bow up high enough so that any water drains out of the bilge while stored. Its very stable and secure.
      Terry
        I use wheel chocks on the trailer. I also have a heavy rubber donut type thing that I sometimes place under the jack wheel for more stability on sloping ground. I'm not concerned about keeping the jack wheel off the ground.
        1998 Capri 1950CL
        3 Liter MerCruiser
          What you've constructed will work if the ground is level and stable (and the 4x4 is vertical). But if it starts to lean in any direction, the 4x4 will act like a crowbar and pry apart the 4 wood blocks you've nailed or screwed together. An earthquake or something pushing your trailer tongue sideways could cause it to collapse.
          You've got the right idea - broadening the base to increase stability. But you want to reduce the leverage by having the support pieces push against the 4x4 higher up. That's why concrete blocks would work better (they're taller).
          Also, if it should start to tip over, the way you've arranged the scrap pieces converts the load into shear forces - the blocks will want to slide and twist against each other, snapping the screws or nails you have holding them together. Structures are usually weakest in shear, especially with all the leverage you've given the trailer tongue, so it's not an ideal bracing structure.
          Compression is generally strongest. Say, laying the scrap pieces flat on each side of the 4x4 to form a cross. Screw them into place there. That alone would still result in a shear force, and against the narrow side of the blocks so it would be even weaker than what you've constructed. So you cut some 2x4s and angle the edges. Screw them in place as a brace between the 4x4 and each scrap piece (forming a triangle). Basically making it look like a king post truss, in both the North-South and East-West directions, with the center beam extending up past the top of the triangle.
          http://www.ashireporter.org/photos/t...13_09/0452.jpg
          If the 4x4 starts to fall over, the weight of the trailer will be converted into a compressive force in the diagonal brace on that side. So the only way the 4x4 can tip over further is if it crushes the brace or rips all the screws out.
            Or just let it sit on the wheel. I've been doing it that way for over 40 years, current boat for 8 years.
            Jeff & Tara (And Hobie too)
            Lake Havasu City, AZ
            And 13 others...
              2-4 or more 2x8 stacked under the wheel, with the trailer tires chocked.
              Say you can't have the drive or outboard fully down , then stack some 2x8 wood under the tires.
                The one I've been using forever is a foot-long times two pieces of 6 x 6 pressure treated post topped with a piece of 2 x 6 . They give me the weather endurance for the ground contact and gets the bow high enough that I can roll it way up in the air. I took the router and made a big slot across where the wheel sets down into the 2 x 6 so it won't go anywhere if I go dancing into the back of the boat. I used to have just dished out place but I made the long slap so I can roll it back-and-forth easily when I'm trying to line up on the trailer ball.
                When I use this I just returned it with my foot snake it out of there and kick it back in the position and I come back later on. I like that better than Cinder blocks because if you drive over to bump it with anything it's not gonna do so much damage.
                  Thanks for the insights! If you guys get a chance I'd love to see pics of your setups too!
                    Agree, that's what it's there for. Additional blocking or a stand is really only needed if you need to raise the bow do to an uneven grade etc.
                      I let my Boston Whaler trailer sit on the jack wheel - no issues. I took a short length of pressure treated 2x8 and cut a large hole in it with a hole saw. I use it to chock the jack wheel. It works the same as one of these:
                      [img ]https://www.picclickimg.com/d/l400/pict/361384824449_/TRAILER-JACK-WHEEL-CHOCK-STOP-RING-Boat-Utility.jpg[/img]
                      2013 Boston Whaler 130 SS
                      Isla Verde, PR
                        this is a funny thread. why would you feel the need to take the weight off of a tongue jack? That is what they are designed for.
                          Sure, but I didn't think it would be good for long term storage over the winter. I always raise mine all the way up so the bilge drains out too. Just figured its cheaper to use a scrap piece of pressure treated 4x4 in case I end up messing up the tongue jack and having to spend $50+ for a new one, that's all.
                            Ditto!
                              X3!
