Bayliner 2455 Ciera starting problem-gctid823532
  • Bayliner 2455 Ciera starting problem-gctid823532
    Hi I have the Bayliner 2455 Ciera with the Mercruiser 5.0ltr Engine the problem I have at the moment is when I turn the ignition key there is absolutely nothing the high pitch warning then nothing, I'm aware the engine has a trip on the top of the engine but on pressing this again nothing happens. I changed out the dash boards and linked up the depth finder and am wondering if this has tripped the engine as the ACY switch light is on constantly and when I press the ACY on the other ACY comes on as well any info would be appreciated.
    Check for 12VDC+ at the ignition switch B terminal.
