ongoing saga of the winnie may 2655 sunbridge-gctid399399
    well, wen't out on the 4th and saw the fireworks in new york harbor. while we are there wa-la! my starter craps out......pulled the boat on the 5th. mechanic came down today to install the mew starter and bing, i need a new flywheel.......will be replacing the oilpan, inspection plate, and will be putting in new gaskets on outdrive plates on both sides of stern as i think i have had a small amount of water coming in. when ever i come back from a day out i pump out for 60 seconds or so. any other thoughts on what i should chk while the motor is out of the boat? and please remember i have 2100 max to drop on all of it....
    why don't you have a bellows kit put in while it is out. Sure is easier. Your mechanic should already know this.
    David
    http://www.cambridgeadvertising.org
    http://www.davidladewig.com
      thanks dave already on that
        What kind of drive is it?
        1989 Avanti 3450 Sunbridge
        twin 454's
        MV Mar-Y-Sol
        Twin chevy 350's inboard
        Ben- Jamin
        spokane Washington
          I'd go back together with a HTGR/PMGR starter motor if your 1991 engine is not already equipped with one.
          Perhaps install a remote oil drain hose.
          Whoever replaces the ring gear, make sure that they do not over-heat the steel.
          I've seen both mechanics and machinists use Oxy-Acet, and heat the ring gear [SIZE]4 wrote:
          [COLOR]"#FF0000" wrote:
          red hot[/COLOR]!
          [/SIZE]
          This is a big NO NO!
