Any ideas on how to remove the norcold refrigerator from a 88-3450 Avanti. Needs to be replaced
norcold refrigerator-gctid822325
what model of norcold is it?... usually there are 2-3 screws along the edges near the seal surface that can be seen. on the door opening side and on the hinge side. none on top or bottom.... some of the fancier models have a plastic trim piece that snaps into place to hide the screws..
NU LIBERTE'
Salem, OR
5.7 OMC Cobra - 15.5x11 prop
N2K equipped throughout..
Screws around the edge of the trim when the door is open. There might be little tiny caps covering the holes.Then there is a a.c. plug on the back left behind the frig.
Have you found one that will fit through the door?. Do you know the one thats in it now will.go out through the door? I couldnt find one that wasn't $1500 that would fit through the door opening which is 19 inches on the lower side of the frig and 22 inches at the top of the door. Norcold are 24 inches.
1989 Avanti 3450 Sunbridge
twin 454's
MV Mar-Y-Sol
Twin chevy 350's inboard
Ben- Jamin
spokane Washington
