I have a leak coming from right under my drive reservoir (Bravo III). Is this something replaceable from up top, or does the outdrive have to come off for this?
Outdrive reservoir leak-gctid821045
No need to pull the drive if your sure it's just leaking from the reservoir connection. Cutting the hose back a touch and a new clamp should fix it unless the reservoir itself is cracked.
