We were out a few weeks ago and just happened to notice that the oil pressure gauge was at 0! we immediately shut the engine off and opened the hatch. Oil filled the bilge. We looked everywhere no sign of oil spraying, really could not tell where it was coming from. Added more oil, noted level on stick. started it up, 50+ psi on gauge, while visually looking for leak. Nothing, got a tow back to the dock, had to start up agin to reverse into the slip, all good. after got the boat tied we put it in gear and ran it for 20 minutes while watching the gauge, bilge and engine for any signs of trouble. again nothing.
My question is could it be running out of the valve covers when the boat is in a forward up position causing the oil to run back faster that the drain can handle causing to leak out of the cover? Maybe a blocked valve housing blockage or loose valve cover?
HELP! driving me nuts to try to figure out...
