This is the first I've rented a slip, I'm going away for a few weeks so I thought this would be a good time to pull the boat out and wash her up.
I've heard on here to use toilet bowl cleaner to get the scum off. Do I apply it directly to the boat or mix it with some water? Can I use muriatic acid or will it eat away at the gel coat?
I want to wax her but do I use regular automotive wax? And do I apply it under the water line of the hull?
I'm going to grease the out drive, is there any other general maintenance I should do while it's out of the water?
